M45Caliber »
https://forums.nicoclub.com/m45caliber-u98401.html
Sat Jun 28, 2008 12:42 pm
OK -- this is strange. '03 M45, 32K miles. Started it up today and drove it over to Costco (about 10 miles) parked it, went inside for maybe an hour (yes, it's AZ and it's 110 outside today)
Came back out, popped the locks and trunk, loaded the car up, hopped in, started the car, quick reverse out, then drive and head out of the parking lot. I notice the AC doesn't seem to be cooling down AT ALL. Then, while at the red lght, I notice the temp gauge is stone cold (hasn't moved) the dash gear indicator is blank (car is in D) and the AC isn't working, The tach, speedo and gas gauge all working fine.
I drive up to a fast food restaurant, pull in and park, turn OFF the car, pull the key from the dash, re-insert the key, start the car -- and EVERYTHING is fine. No issues. Drive it home. Stop it, re-start it - everything is OK.
This has me a little frightened - is this the begining of a potentially expensive electrical problem? Anyone else seen this before? Thanks in advance -- Drew
1997 Q452001 G202003 M452008 EX35
