Lost of torque
motoxris
Car: 92 240sx coupe
Hey everyone. Have a KA 240. I just did a clutch replacement this week and I'm feeling a little bit of a lost of acceleration. Only since the clutch swap.
So thees are my possibilities so far.Broke a couple of wire from two transmission sensors, (shouldn't be relevant to this case)New exhaust leak, (witch doesn't really do much after the O2 sensor)I put new fresh AMS oil and filter,(threw that one in for the hell of it)The O2 sensor wire was tugged on a little when I was maneuvering my hands and things aroundThe possibility of bumping the distributor So this is what I have for now. I thought I would let you guys have a little fun with this before I go tinker with stuff. Thanks guys.
Modified by motoxris at 2:11 PM 2/7/2009
S13Joe
Car: 92 Coupe
could be the exhaust leak you speak of...
leesredgt
Car: 1992 Toyota MR2 N/A
1991 Toyota MR2 Turbo
Did you install the clutch right? I know that sounds like a stupid question but,your clutch could be slipping.Or not engageing right.
motoxris
Car: 92 240sx coupe
I f it was slipping it should be revving out more with out accelerating. The engine isn't really pulling quite *** hard.
motoxris
Car: 92 240sx coupe
There is also the center bearing issue I had. I had an other thread about that. I don't know if it is something that could be the problem.
zerothread?id=401696
