Lost my Lug Wrench, Wheel Nut Wrench...Replacement?
mateen110
Car: Nissan Pathfinder
Hey all,
I can't seem to find my lug wrench, also know as the wheel-nut wrench. (See image below)
Now I was wondering if I could find a generic one, or a universal one that works on my 2002 infinti qx4 (Remember, it needs to work with the spare tire as well, as in raising and lowering it)
I don't want to get ripped off at the dealership for this piece. I have the jack and the long metal piece, but now the lug wrench. I am simply looking for that lug wrench
Thanks!
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
Junkyard would be a good bet. I'm sure many Nissan and Infiniti vehicles use a similar tool which will work for the spare tire mechanism.
Alternately, you can try your local dealer; the part number for this wrench is 99545-2S400. Only $7.32 before shipping at Courtesy Parts!
mateen110
That part looks like its for the R51 and 2005-2012.
Chuck Tribolet
Car: '01 Nissan Pathfinder
'87 Chevy Corvette
'01 Toyota Camry daily driver
'98 Boston Whaler Montauk
At least on my '01. the lug wrench also works the scissor jack via about a 1/4" square hole in the middle of the handle.
Chuck
Towncivilian
It doesn't matter, it looks identical and the part number is the same. The pictured part has a 1/4" square hole in it, and I'm sure it's a 21mm wrench.
mateen110
Problem solved, thanks!
Towncivilian
You're quite welcome. Are you going to purchase one of those?
mateen110
I just got it from the dealer for $8. I had to use the 2012 model though. Same part #, but my 2002 model was $40. And I had to order from Nissan because infiniti dealership was 2x nissan.
