you are lucky. the infiniti dealer didnt keep that key-code on hand, hence the video i made lolkeitarosan wrote:Thanks for the info and video. Looks like this is going to give me a hard time. I'll contact McGard as well just in case. I called my local dealer and they said that they will get the key/tool for me and let me know when it arrives. I forgot to ask for the price though so if they call back and ask for a hefty price. I'll just tell them to keep it.
You can get a replacement wheel lock set from any Nissan dealer by simply bringing them your VIN. You cannot just get the key and the set is pretty expensive. If the lock isn't that important to you I would suggest just switching the locks out for regular lugnuts which are about $5 each. Hope this helps!keitarosan wrote:Hello. I lost the lug nut special tool. Anybody know where can I get a replacement and what it's called? I was in a hurry replacing my all season and I forgot that the tool is still on the tire when I drove away.
while that method works... it ruins your socket. who wants that? now you have an incomplete set. that would annoy me to no end.Rogue Jarhead wrote:I just use a 12 point socket (cheap kind) and a 3 lb hammer. Hammer the socket over the locking lug nut, it has to fit real tight, then hit it with my air impact. Usually comes off on the first try. Ruins the socket so use a Chinesium brand don't use your good Mac or snap on . To complete the process you toss the old lockers in the garbage and replace with a regular lug nut.
