Loss of spark at coil....KA24de-t Maybe the CAS???
Afliction523
Car: 92 S13 KA-T Coupe
I basically am experiencing a random loss of spark at my ignition coil. Im thinking it is my CAS because I can start the car usually, but when driving I randomly loose ignition while having power at the coil. I have replaced the factory one when this problem started with a MSD Blaster coil. The problem persisted. I then replaced the ignitor.....still no luck. I drive about 10 minutes and bam it dies. I play around with it for a bit and it starts back up. This problem happens everytime I drive the car, and this is the last thing I can think of. Like i mentined before 9 out of ten times the car starts eventually. Im thinking my CAS is damaged but have not inspected it yet. I beleive its also called the cam position sensor. Any ideas???
Modified by Afliction523 at 6:36 PM 8/8/2007
Afliction523
Fixed, one of two possibilities. Freyed tach wire by ecu, or semi non seated daughter board for my rom tune. I pushed the board back in and re taped that freyed tach wire....no issues yet.
