Psychobob_007 »
https://forums.nicoclub.com/psychobob-007-u91997.html
Sun Aug 03, 2008 6:00 am
i would definitly check your O2 sensor, your Coolant temp sensor, i would then proceed to fully cleaning your MAF, if you hadn't done that already, and if that didn't work, i would check your catalytic converter to see if it is clogged. a good rule of thumb is to check all the little things, plugs (Gap them correctly), cap, rotor, etc... one more thing. you might go down to your local parts store and see if they can test your coil. heat causes resistance in electrical components which robs you of power. any NAPA store should have a tester. good luck.
