loss of power in the high rpm
truepinoy
Car: 240sx 1990
my car has started to show a break up in power when im on full throttle around 4500rpm to 6000rpm. when this happens back smoke sputters out the back. soooo i thought it was just the spark plugs, i got some new ones and gapped them down to .022..it still broke up...i bought a new cap and rotor, still the same. my wires are semi new, i also have an msd blaster coil. could this problem be caused by a bad maf (n60 soldered to harness), or wrong fuel pressure (my fpr is screwed, it reads around 50-60psi at idle)..........could heat be messing with my sparkplug wires as well? any suggestion will be greatly appreciated..thanks
truepinoy
Car: 240sx 1990
oh btw its 12psi on a t3/t04e
zach-Ka
Car: 1990 240sx (SR)
50-60 psi at idle is crazy high. I can only imagine how high it is under vacuum. I would guess that you are putting more fuel into the cylinder than the plugs can ignite. Thus the unburt fuel coming out of the back.
http://cgi.ebay.com/ebaymotors/CB-FUEL- ... arQ5fParts
My friend has this on his s14 and it works great. After doing some research, Megan gets their FPR's from the same manufacturer as these EBAY companies.
http://enjukuracing.com/isis-fuel-press ... -9060.html
You will need this to make it work though.
truepinoy
Car: 240sx 1990
do i still need the adapter even for the ka24e?
zach-Ka
Yes. The EBAY kit comes with a "universal" adapter but it doesn't fit.
truepinoy
Car: 240sx 1990
and your friend had good results with it? ...it actually sounds pretty good.
zach-Ka
Yeah, he actually had the same problems but it was not enough fuel. He loves it, he has had it for probably 7-8 months and has had absolutely no problems, and It also looks really good.
