Jesda wrote:Not officially.
Means only 1 or 2 known 1993 G50 have had the metal backed guides on NICO or its predecessor boards. I think it is only one, and it was not established beyond a doubt if it came that way from the factory.
Hence, if you have a 1990-1993, you must remove the timing chain covers and look, unless you have written documentation to the opposite. Beware that usually only the slack side guide was replaced in many of these instances, so still worth looking. Who knows if all the pieces were recovered from the oil sump?
Modified by maxnix at 11:51 AM 11/9/2006
