SR24DET wrote:Y dont you play with the distributor and see what happens?
The distributor, or you mean the idle air control valve?
driftneil wrote:Whats your idle like?
My idle is smooth, and the RPM's are at 850. It doesn't bog or misfire etc. It only does that when I accelerate while driving.
Kraelic wrote:I'd suspect the timing as well. I didnt follow the proper procedure to time the engine and it felt weak after the guide removal. My timing light was showing 20 degrees before TDC. Then I found out which sensor was the throttle position sensor and unplugged it to time it proper. I set mine to 16 degrees before TDC instead of the stock 20.
Hmm ok. So i'll probably have to get timing light. Do you by any chance remember what kind of timing light you have? Cause I don't want to buy a crappy one that will get my timing all screwed up etc.
Kraelic wrote:Just read the part about timing it higher than 850 rpms.. yeah they have the timing set wrong. the idle air control screw sets the rpm not the distributor.
Alright, so what does the distributor do exactly? It doesn't affect the RPM's or the misfiring i'm experiencing?
