rmezz13 »
https://forums.nicoclub.com/rmezz13-u82416.html
Sun Jul 27, 2008 4:43 am
the link that beancooker provided is your answer.... i did it - it works the same on the Z as it does the G.... make sure you get everything as close to the times as possible. and the 3 beeps you here when you first turn the key on, is your first three seconds..... i'm not gonna recommend it, but i counted - one, one thousand.... two, one thousand.... etc. worked!
