mechanicalmoron »
https://forums.nicoclub.com/mechanicalmoron-u183526.html
Sat Apr 20, 2013 8:14 pm
That's not deleted, that's chopped off. You need an o2 sensor of some sort, and you need to fix that.
I would assume you're taking your foot off the gas, revs drop so it's harder to make boost, and the closed throttle pushes all the extra boost it's making during that time out the wastegate. I've never driven a turbo car, so this may not be it at all. But especially if there's a boost leak as well, it makes sense to me. You could try a flat shift, or shift with reasonable throttle at least and I bet it wouldn't happen.... but I alse wouldn't drive the car at all, other than to hobble it very carefully to the parts store, withouout an o2 sensor.
There shouldn't even be a plug for the o2, I expect. My replacement one just came with a crimp connector and some heatshrink. You realllllly need it.
