Kompresshun wrote:It does sound like your rings are starting to wear out.
There are a bunch of "snake oils" out there that can "fix" the problem or mask it, but honestly most of them end up doing more harm than good. I would keep feeding it oil until it gets worse because a quart a month really isn't that awful. If you plan on rebuilding it after it gets worse, i'd avoid the additives but if you plan on going another route then you could try throwing some Lucas Oil Stabilizer in it or some Restore to squeeze some more time out of it.
