craz4240 »
https://forums.nicoclub.com/craz4240-u47081.html
Mon Jul 02, 2007 8:31 am
Well the moment of truth came and I dunno if I am totally retarded or what but the damn car will not start.Heres how I have it wired up in case someone can shed some light for me maybe.
Ok the factory fuel pump relay is in tact in it's factory position with it's factory wiring,the fuse box under the hood has nothing wired to it.So I had a bit of a problem getting 12v switched to the black/red wire on my f3 plug...so I decided to test the wire going into the back of it...12v,with the plug plugged in the wire on the male plug was only getting 4-4.5v.So I just added as many wires as I thought I needed to the 12v switched source behind the f3 plug (black/red wire).Now according to my rb20 fsm the eccs relay and the ignition relay get ignition power from the white/black and orange wire on the eccs relay,and the white and the orange wire on the ignition relay .So first of all I have a spare harness or 2 and I decided to pull the proper color wires out of this to make the harness,in doing that I noticed that the orange wires from the 2 relays share the same wire along the way.So what I have done is wired the white wire on one relay to the black/red ignition power wire from the dash harness,the orange wire from 1 relay to that black/red wire,and one of the white/black wires off of the relay to the black/red wire.And then I patched the other white/black wire to pin 49 0n the ecu,which is control unit power supply.The guide to wiring this is kinda messed cause from what I have interpreted in wiring to the 2 white plugs from the rb harness is that the guide is matching wires from the female side of the plug which once the male plug is hooked in some of the wire colors change up.I have the 2 white plugs wired exactly as Wulfgangs guide says using this philosophy.I also have the orange wire on the f3 plug wired to pin 43 on the ecu for the cold start enrichment.My ecu has power,my coils have 12v,my pump was priming and turning off like it should but today it wasn't turning on at all unless I grounded out the black/pink wire comming off the relay...then it runs constantly.
Can anyone tell me what the hell is going on...this is not a general question this is a catastophy and I need to fix this asap...cause right now this car is all I have for work as stupid as that is.
Thanks a million Kendal
