losing coolant after Mishimoto rad install
Shoey2
Car: 1990 300ZX Fairlady Z Twin Turbo
iv been noticing a steady loss of coolant over the months after my Mishimoto rad install. seems to be steamy coolant residue on the side of the rad under the cap. anyone one else here that can confirm my suspicions? if so who makes the best quality replacement?
ThisIsSparTTa
Car: 91 300ZX TT 2+0
Are you using the correct pressure cap for the system? Maybe its allowing it get too hot without relieving the pressure, etc to the overflow tank.
Shoey2
its the one that came with the rad, says its 1.3 bar. thats about 19 psi if my math is correct?
ThisIsSparTTa
19 seems a bit high, but I'm not an expert in this area:
http://www.z1motorsports.com/advanced_s ... diator+cap
NISSAN OE Caps are rated at 0.9kg/cm (12.6lbs) and 1.2kg/cm (16.8lbs) for turbo vehicles.
NISMO Radiator Cap - Rated at 1.3kg/cm (18.2lbs).
Z1 High Pressure Cap - 1.2 Bar (17.4 PSI) with a relief pressure of 1.37 Bar (19.9 PSI).
Greddy - 1.3kg/cm2 (18.5psi)
Shoey2
the mishimoto cap says 19 lbs on it. it just sees a little flimsy and chinese by comparison
Mishimoto
Vendor
Car: Many!
Shoey2 wrote:iv been noticing a steady loss of coolant over the months after my Mishimoto rad install. seems to be steamy coolant residue on the side of the rad under the cap. anyone one else here that can confirm my suspicions? if so who makes the best quality replacement?
Shoey2,
Thanks for posting up! If you are noticing a leak coming from the cap, we would be happy to replace. Can you contact us directly at [email protected] with your information?
Please let me know if there is anything else we can help with!
-Pat
DCaff300ZX
Car: .
1993 CRP TT- Modified
Wow, now that's some customer service right there...finds your post and responds to help out! :bigthumb:
Mishimoto
Vendor
Car: Many!
DCaff300ZX wrote:Wow, now that's some customer service right there...finds your post and responds to help out! :bigthumb:
:dblthumb:
