losing clutch pedal abd car overheats
s20700134
Car: 1989 240sx coupe
i drive and the clutch is fine, but once i start driving spirited(main duty of the car), i start losing the clutch pedal. the pedal doesnt want to disengage the clutch. when i first start off with the car cold, the engage/disengage point is high in the travel, but when i start pushing it, that point gets really low in the travel(to the point to where its not in the pedal travel at all and i cant put it into gear). oh, and the car overheats and the coolant boils over along with this clutch problem(pretty often). i just got into 240s and this is my first one.
TotallyStock
Car: 1992 240SX Totally Stock 82k Miles
s20700134 wrote:i drive and the clutch is fine, but once i start driving spirited(main duty of the car), i start losing the clutch pedal. the pedal doesnt want to disengage the clutch. when i first start off with the car cold, the engage/disengage point is high in the travel, but when i start pushing it, that point gets really low in the travel(to the point to where its not in the pedal travel at all and i cant put it into gear). oh, and the car overheats and the coolant boils over along with this clutch problem(pretty often). i just got into 240s and this is my first one.
The clutch is hydraulic. check your fluid level and top it off if it's low, but you may need to bleed the system. Or, it may simply be the master or slave cylinder needs to be completely replaced. ----As far as the overheating goes, be careful with that one. The head gaskets in those engines are not forgiving of high temps --- the cause of the cooling problem could be any one of a dozen things, but check for obvious leaks first and work upwards from there. If the temp gauge even teases you that it might go red, shut down IMMEDIATELY, once again, The head gaskets in those engines are not forgiving of high temps.
s20700134
i bled the system 2 days ago. solved the pedal problem for a day, then it came back today twice as retarded. the overheating is from a rusted radiator core i think. the overflow tank is a nice orange carrot hue.
s20700134
gonna just replace the clutch mastercylinder and slave cylinder
