Synthetic is thinner and can exacerbate leaking issues, but I have never heard of it causing burning. Maybe it slips past the rings or something? I ran conventional oil only before this most recent change so synthetic absolutely is not the issue, and I am not particularly interested in switching back. See below for the explanation of that.Kompresshun wrote:Sorry for being late to the game here, but I have your answer and this completely fixed the problem with our QX4. Run conventional oil only - no synthetic or synthetic blend AT ALL. It sounds absolutely crazy and stupid I know - I thought the exact same thing.
The Infiniti Service Department told us to do that and I thought they were completely full of crap. I switched to regular Valvoline 5w30 and it never used another drop of oil between oil changes.
After doing further research, these engines were only designed to run on conventional oil and for some reason the synthetic burns in it. The reason you're not seeing it out of the tailpipe is because synthetic oil doesn't burn like conventional oil does, therefore you're not likely to see any smoke. No, there is no logical explanation for it, but I have seen this issue quite a few times and this is what solved it.
Is there an easy way to get to those to check them? I plan to change the PCV when I do the spark plugs when it warms up outside. I know it isn't good for it to burn that much, but I am not sure that it is burning it. There is no evidence besides the loss. Although I can find no evidence of leakage either. As far as the cats go, I will be having a new exhaust put on very soon (resonator broke off for no apparent reason), and I will get them checked then if I can. There is literally nothing else wrong with the car.Kompresshun wrote:Another possibility is that there was an issue with the baffles in the valve covers getting clogged. Some have mentioned you can change the PCV valve and it will reduce the consumption, but the valve cover where the PCV valve is located may have to be replaced to make a difference.
Keep in mind that if it's burning oil, then eventually it could ruin your catalytic converters and cause bigger problems down the road. Not trying to be negative here, but it's just one of those things that probably should be dealt with if you want it to last for the long haul.
In this picture that you posted, it seems you are only about 1/4 of a quart low, not a full quart...nickelghandi wrote:Kompresshun, hat sounds like a lot, but I'll look into it if I get the time.
Quick update:
I have been checking the oil at every fill-up since I changed it and it hasn't looked low, but I checked it yesterday and it was about a quart low. I topped it off and am prepared to do that since I went through nearly 4 tanks of gas before I needed to add oil. To me that isn't bad for an old car. I checked a couple of the spark plugs (a chore without removing the upper intake manifold), and none of them are fouled up. It seems possible that there could be a leak somewhere that I have not been able to find. There are some spots that look like old leaks so maybe I'll have those seals inspected or something. I don't know. One quart per 1000 miles seems consistent with why it was so low when I changed it. I'll continue to monitor it and top it off until something presents itself.
I have pictures below of the dipstick and one of the plugs I pulled. I will be replacing the plugs soon and I'll do the PCV at that point as well for preventative maintenance.
Yes, you are correct. I should have corrected my post. I have discovered what the issue is. I figure my head gasket is blown. There is a small amount of coolant in the engine bay that keeps showing up after I wipe it away, and yesterday, after having checked the oil and adding when necessary several times over the last few weeks and not seeing anything, I removed the cap to add some oil, and I discovered the gruesome sight pictured below.04pathse wrote:
Thanks for the suggestion! I would hate to take it to a shop and have them do all the labor getting to the head gasket only to find that it didn't need replacing after all.atraudes wrote:White foam/tapioca is a sign of moisture in the oil, which could be from a blown head gasket or simple condensation which can accumulate during the winter, especially after sitting for long periods or from short trips. If the oil on your dipstick has the same funky foam, then it's a blown head gasket. If not, then it's not nearly as big a problem.
That PCV valve is in a bad spot, and will require removing the intake manifold to replace.nickelghandi wrote:
I might just take it to the shop and have them replace the PCV valve and tell them to check everything else out while it is that far disassembled.
I did not. The mechanic said I was most likely burning it due to some internal leak as my exhaust is now blackened at the tip. He said it could go another 100k miles or another 5k miles. This was after PCV and EGR were replaced and all checks for leaks that could be done were done. My solution has been to buy another car for driving around town and keep my Pathfinder for the winter when I need the 4X4.attofarad wrote:nickelghandi -- did you ever resolve your oil problem?
