DriftingisLame »
https://forums.nicoclub.com/driftingislame-u25409.html
Sat Mar 29, 2008 3:36 pm
My maf wire was hangin out in my engine bay right after I finished the swap. Fell on to the turbine housing and melted, grounded out, and fried my ECU, car just cranked and cranked with no spark or fuel. Gauges/lights worked, thats controlled by something else.
I pulled the cover off the ECU case and found a black spot where a connection was broken, dabbed a little solder on it and it worked again.
If your ECU fried like mine did, then its pretty easy to find, the black spot was obvious.
Good luck, although that may not be your problem.
-Max
