mkaylor »
https://forums.nicoclub.com/mkaylor-u225896.html
Wed Oct 02, 2013 10:06 am
2007 Nissan Versa SL. Working fine, then all of a sudden getting on the interstate it lost power. I pulled off and then limped home at about 40mph. After a short time in the garage poking at things, it started and ran good for a couple of miles, then started doing the same thing. Looses power and won't idle. Once it dies, I put in Neutral, crank and it runs full speed for about a block or two and then does the same thing.
I did put an aftermarket O2 sensor in about a month ago to pass inspection.
No check engine lights. Oil, Water look good. Started just fine this morning, but I didn't dare take it 25 miles to work. Did seem to hesitate just a hair when I killed it.
Spoke with Nissan on the phone, they said probably not the Packs and probably not the Fuel Pump. They say maybe wiring or Ignition Module.
Any Thoughts????,
Mike
