NY_Pito_NY wrote:
i just installed a new alternator....and a new battery...i registered at 14 volts..it lasted a day or two now it went down to 12 volts...and a slight hind of the battery icon on the dash board is beggining to light up...what could be the problem...could be drsining the power...shouldnt thd alternator help with the recharge of the battery...???? Please.snyone have any ideas.
Here is a $500 piece of advice I wish I had earlier: clean the nut/bolt connection inside the engine compartment fuse box. It deceptively looks like a bolt holding down the fuse box, but its the main power point from the alternator. It may be tight & look clean when assembled, but its probably not making total contact due to a thin film of metal electrolysis.
I took mine apart, sanded it, tightened it down... and VIOLA no more electrical problems. Perfectly running car. Many things have now come back to life. My alarm system even works now!!!
Wish I had known this before buying a new alternator...
