Loose shifter
RedOctane
hey guys,I just bought this 92 300zx n/a in feburary. I haven't had many problems besides the bad clutch, steering going on and off, and the new problem, my loose shifter.I had the clutch replaced by a stage1 clutchmaster.The power steering goes on and off while driving, but trying to turn when stopped makes a slight grinding and buzzing sound.The other problem is the loose shifter. My shifter will wobble (about 2-3 inches diameter) in Neutral, and in and gear.
Thanks.
180fan
Car: 89 fastback
change the lower plastic bushing on your shifter. the grinding and buzzing sound in your ps, how's the reservoir? use dexron 3 atf if you're running low. my 240 makes sounds like a whirling sound once in a while if my ps fluid is running low. might want to give that a try.
RedOctane
thanks. there maybe a leak in my ps tho, i just filled the resevoir up last month, and now its low again. but when i do add fluid theres no change in the steering's reactions.
NISTECH
check the seal on the front of your pump maybe blown out
bobdhead39
Car: Cars maybe?
Where can someone get that nylon grommet at the base of the shifter?
RedOctane
the bushings? u can get urethane ones or rubber at an autoparts store. best bet is NAPPA or PEPBOYS. i still need to get mine, but right now i have too many bills to get off my chest.
bobdhead39
Car: Cars maybe?
Thank you.
bobdhead39
Car: Cars maybe?
HAd to go to Dealer for the grommets. It was $2.72.........
RedOctane
I took apart my shifter and looked at the bushings. i'm missing a bushing but it seems like the roc to the transmission is also loose. i have to go now but i'll get back to it in a second.
...*****ing girlfriend.
thanks.
NISTECH
RedOctane wrote:I took apart my shifter and looked at the bushings. i'm missing a bushing but it seems like the roc to the transmission is also loose. i have to go now but i'll get back to it in a second.
thanks.
LMAO wait till you get married guy
RedOctane
lol i dont wanna think about that so soon....
1 year w/ her is enough
bobdhead39
Car: Cars maybe?
I have an extra bushing if for some reason you cant get one.
