Loose inside door handle
LaCapitalRue
Car: Acura NSX, 2007 Mercedes E350, 2003 M45
My driver side inside door handle is loose. Its still connected enough to close the door but there is half-inch gap between the handle and the door.
Anyone else have this issue? Any suggestions on how to correct?
szh
Car: 2018 Tesla Model 3.
Side question: please remind me which model year do you have? I think it was a 2003 or 2004 M, right?
You might want to take a look at the Service Manuals on this ... the link is in my sig.
Z
LaCapitalRue
2003.I definitely took advantage of your link. I did some preliminary searching and didn't find much on the inside "pull" handle which is why I reached out to the forum. I'll keep digging
CakeDaddy
Car: Y34,Pathfinder SE, Mercedes CLK500AMG Sport Pkg & A Fleet of Premium Avis Rental Cars
LaCapitalRue wrote:2003.I definitely took advantage of your link. I did some preliminary searching and didn't find much on the inside "pull" handle which is why I reached out to the forum. I'll keep digging
Your problem may be as simple as a loose bolt that holds it in place. It may be in your best interest to pull the panel off and inspect it yourself. I've pulled numerous door panels from Mercedes to Datsuns to resolve such issues. You only expense may be replacing a few plastic clips. good luck.
