Loose Gear Engagement - please HELP!
240lookis
Car: 1990 240sx hatch
Yesterday I bolted up my transmission/driveshaft/engine. I poured in approximately 2.4 liters of manual transmission fluid (75w-90 GL-4).
After everything was together, I sat in the car and decided to shift through the gears for fun. My first impression was that the engagement was quite loose and sloppy. Not good. 3rd gear hardly engages, and can easily be pushed out by a soft touch.
I was not happy. I started browsing the internet and found a deal on zilvia for the Circuit Sports v2 solid shifter (http://www.phase2motortrend.com/cispv2soshs11.html) for $55 shipped. As i was about to buy it, i wondered if this would even fix it.
What do you think? Do I need new bushings? Rods? Will this even be a problem?
Help me out NICO.
xX RB Xx
Car: SE3P, FC3S, FC3C.
is your shifter bolted down all the way?
240lookis
yes it is. all 6 bolts all the way tight.
nifares240
Car: 1993 240sx Black-Project Car, 1993 240sx Red-SOLD, 1994 Sentra, 2004 Nissan Sentra SE-R SPEC V-Daily, 1999 Toyota Camry
you need a short shift to get those tight, crisp, feel if you have a stock shifter.
240lookis
well, thats what i hope it is. im going to by the circuit posrts solid shifter either way, but hopefull my 65k transmission which i recently bought isnt dead.
nifares240
doubt that its dead. its the blown shifter bushings that go in these cars.
240lookis
ok, thats sounds right from the research ive done.
the rubber bushing at the bottom correct?if so, a new shifter setup would theoretically fix the problem, correct?
adrianfromthecastle
Car: 1992 Nissan 240sx
240lookis wrote:if so, a new shifter setup would theoretically fix the problem, correct?
yes, theoretically
nifares240
looks like a b&m piece.
Razi
Car: Moo
You could rebuild it.Here is what MrGreeneyes told me in his build thread.
. wrote:1x 32204P (upper snap ring)1x 32850N (socket assembly)2x 32879 (wave washer *i use two, one below the top snap ring and one in the bottom OEM spot*)1x 32862 (boot)1x 32861 (bushing for the bottom of the lever)
Then assemble in this order:
FROM THE BOTTOM UP (aka how you'll reload the shifter)
wave washersocket assemblyshifter lever w/ ball pivotsecond wave washersnap ring w/eyelets"c" shaped snap ring (the one WITHOUT little eyelets in it) (save this from your current oem setup)
the second wave washer takes up a lot of the slack, in case you were wondering.
I've already ordered the parts on that list, they are en route to my house.I'm rebuilding my stock shifter to replace my Megan shortshifter.
240lookis
nifares - that is a picture of a b&m shifter i found for reference.
razi - how much did it add up to. if its any more than 55 shipped im just going to go with circuit sports for the ease of everything.
thanks for the help though.
zach-Ka
Car: 1990 240sx (SR)
240lookis
thanks.is the HKS spring kit really worth $91 more than oem?
im going to order the oem spring in a bit.
are the springs on the transmission accessible right under the car?
s14selfbuilt
Car: 96 240sx
well if your gonna replace it, you might as well upgrade to shorter throw since stock is like an S10 shifter, dont rebuild it cause thats just gay. i have a used megan racing and it works good for cheap sh*t. also make sure you have everything placed properly under the snap ring plier.
Gabes13
Car: rb20det s13
lol @ $1 compared to $90.
zach-Ka
s14selfbuilt wrote: i have a used megan racing and it works good for cheap sh*t.
You might not want to call something sh*t while your recommending it...
240lookis wrote:is the HKS spring kit really worth $91 more than oem?are the springs on the transmission accessible right under the car?
I honestly have no idea, and I am pretty sure you can get to it easy.
Razi
Car: Moo
240lookis wrote:razi - how much did it add up to. if its any more than 55 shipped im just going to go with circuit sports for the ease of everything.
Like 40 shipped I think.
240lookis
oh damn. thats nice. whatever, i just ordered the circuit sports one. ill update this after i install it
