freakonaleash1187 »
https://forums.nicoclub.com/freakonaleash1187-u12997.html
Mon Mar 05, 2007 3:56 pm
Nissan recommends Dot 3 Brake Fluid for the clutch. My clutch fluid is clear (which most is), but it comes in a few different colors, like I have seen blue and purple clutch fluid, but there is definitely not a brown clutch fluid.
I haven't changed my clutch fluid, but I believe you can attach a hose to the bleeder next to the slave cylinder on the transmission and pump the clutch and all the clutch fluid should drain out.
