Lookout for AC noise
Guat
Car: 2007 Versa SL Blueberry, CVT and tech package
Hi All,I just went to the dealer for my oil change (SL, 1 year, 14000km) and I told them that I noticed the AC was a little loud especially during the winter when the defroster was on. They told me that there was a service bulletin out and that they will fix the problem. Took me 2 hours for that oil change but at least they fixed the AC noise.
Listen to your AC, if it sounds a bit loud, chances are it is.
srellim234
Car: 2007 Nissan Versa SL hatch w/CVT
(sold 08/2011)
2008 Toyota Prius
(purchased 04/2016)
Is that noise inside the car or outside? Ours just started getting really loud, like a jet engine revving up, outside. Not consistently, and not related to the compressor firing on and off. But really loud.
Onyxblue
Car: 1990 300zx n/a, 08 Versa SL, 07 Pathfinder SE, 08 Sentra
As I remember, the recall was for 07's V - they fixed it for 08
Beginningsend87
hmm that would make sense. I have the same anoying noise when im driving or sitting still... clicks alot too. ive got 15,5xx on mine.
Guat
It was inside the car, it just sounded like the compressor was running loud (which it was). Now that it's fixed when I hit the AC button the compressor is very quite (as it should be). I especially found this throughout the winter when I had the defrost on.
xtwoonamatchx
i dunno if its the same noise, but unconsistantly there is a noise coming from under the hood... i dunno how to explain it, but sometimes when i start up it will be really loud, lasts about a second, its usually when i first turn on the ac... is that normal?
anyone have a transcript of the service bulliten?
LinWin
Car: 2008 Nissan Versa Sedan 1.8 SL
Do you know when this service bulliten was issued? I have had my Versa for about 6 mos.The noise is very annoying and I find the AC doesn't work as efficiently at these times.I also had some noises from the fan in winter. I hope my dealer will rectify the problem too. 2 hrs.......it's worth it.
