looking to put 18" factory infiniti m class rims on 2000 maxima what size spacer
jess.dave
Car: 2000 nissan maxima
A friend of mine gave me the rims off his 2006 m class infiniti.I want to put them on my 2000 maxima.Anybody ever do this?What thickness spacer do i need and where is a good place to get them? thanks Dave
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
I'm not sure. Do you know the measurements for the wheel? Offset? If you know that, it's easy to figure out. I can't find any details on what the offset is on those wheels, though.
You're talking about the 8-spoke wheels, right?
allensteiner
Car: 1995 Nissan Maxima GLE, 2005 Pontiac Bonneville SE
i doubt you'll need a spacer at all. why don't you take your stock wheel off, put the new one on and see if it fits without touching anything.
szh
Car: 2018 Tesla Model 3.
allensteiner wrote:i doubt you'll need a spacer at all. why don't you take your stock wheel off, put the new one on and see if it fits without touching anything.
Unfortunately, I doubt this is accurate.
The stock OEM 2006+ M wheels are 47 and 50mm offsets (depending on whether you have the 18" or 19" wheels). If you can make them fit on another Infiniti or Nissan without spacers, I would be extremely surprised! These stock rims will contact suspension components all too easily, I think.
So, in most other Nissan/Infiniti cars, you will need a 10 to 25mm spacer (depending on car and how "flush" you want it, etc.), and that is horribly large IMHO ... your opinion may vary! I think it is better to sell those OEM wheels and get something that is a better fit for your car without spacers!
Z
szh
MinisterofDOOM wrote:I can't find any details on what the offset is on those wheels, though.
Stock OEM M wheel info is in the Basic Specification stickies in the M35/45 forum (link is in my sig).
Z
allensteiner
i thought the bigger the offset the deeper the center of the wheel sits, so it might stick out more - but i'm not a specialist so nobody quote me
but doing simple math...my tires are 245mm, stock se are 215mm so i have 30mm+ with 40mm offset and they fit perfectly. that's why i thought his oem's should fit no prob. you're saying they're 18 or 19"...yeah, i was wrong because a tall wheel will hit the shock on the front with a taller sidewall - mine are low so they fit just right.
but like szhosain said - get aftermarket - they'll look better.
szh
allensteiner wrote:i thought the bigger the offset the deeper the center of the wheel sits, so it might stick out more - but i'm not a specialist so nobody quote me
Unfortunately, no. But, it does depend on the sign of the offset too - i.e., whether it is positive or negative offset, of course! Wheels for Nissan and Infiniti generally have positive offset numbers.
Since the hub where the wheel mounts does not move in relation to the car, the large positive offset (in this case of the 2006 M35/45 wheel) means that the center-line of the wheel sits more inwards (i.e., away from the fender) than a lower positive offset, and hence will contact the suspension components all too easily, IMHO.
See http://www.nicoclub.com/tech/wheel-tech.shtml for more information.
allensteiner wrote:but like szhosain said - get aftermarket - they'll look better.
The best solution, yes.
Z
