Dano »
https://forums.nicoclub.com/dano-u2493.html
Mon Sep 11, 2006 12:34 pm
If your still running on stock tension rods, chances are the factory gel-filled rubber bushings have either cracked and oozed out the goo, or are going to shortly. I had that problem. SPL Parts, who is also a NICO sponser, sells the sweetest tension rods i've seen with their SPL v2 tension rods. I run them on my car and looove them, the stock bushings are replaced with spherical bearings that do not wear out. Under $200 and worth the money, also, if your running on stock tie rod ends, chances are the ball joints are worn out, replacing those will also yeild you better steering.
Hope that helps, let us know if you have anymore questions!
