I got '14 AWD SV Juke that's still on 17" 's , but went to 235 wide , I believe that is double -wider . AWD keeps 'em all the same , no bigger on the back . Definitely go wide , I also went 50 profile from 55 If remember correctly - Michelin the way to go pilot sport 4 all season .
A very important mechanical upgrade with timing componants on your erlier 2010 . Up to 2013 supposedly, timing set problematic , supposedly as of 2014 - on was revised , A TSB exists , maybe recall on certain years?
Stopping from 80 mph is " SICK " . Sport 4's got a 500 AA A UTOQ rated.
Factory Oversized on Juke brakes , ya know?
p.s. Tip .... in summertime heat , pull out that goofy engine cover and remove the rubber ' hood-seal ' above firewall in back - let as much air flow into - around - and out of engine compartment ........cool that F 'n turbo as much as possible !!!
