That's the route I'm probably going with. However, I may just try a direct drop in cxracing turbo for reliability's sakeeh? wrote:Stock turbo ~10psi, greddy style intake manifold, fmic, 3" exhaust, tuned vipec = 300+whp easy
You don't need a new oil pump/collar.
i'd run with the stock turbo over that cxracing one, but that's just me.marshallpre1 wrote:However, I may just try a direct drop in cxracing turbo for reliability's sake
I hear the stock turbos grenade with its ceramic blades?gawdzilla wrote:i'd run with the stock turbo over that cxracing one, but that's just me.marshallpre1 wrote:However, I may just try a direct drop in cxracing turbo for reliability's sake
Just 12 psi? Really? That's pretty good. My stock Supra dynoed 302whp with stock twins at 11psi.meet07 wrote:Its gonna take about 12psi to make numbers close to 300whp. If your boost spikes over 12lbs(which it will with a internal gate) the turbo is gonna make a rattling noise... That means your over spinning the turbo so I would replace it with anouther t28 that is good up to say 350hp.
A used EMS of some sort you can probably pick up for under 1000. Like a PFC or *maybe* and AEM.marshallpre1 wrote:
what about engine management? What do you guys use? I'm trying to keep it under $1K and still have control of timing, etc. The Vipec I was planning on using was going to cost me $1500...
PSI is completely irrelevant comparing different setups like that.marshallpre1 wrote: Just 12 psi? Really? That's pretty good. My stock Supra dynoed 302whp with stock twins at 11psi.
there is a simple reason to upgrade the Intake manifold on RB20's and 25's. much shorter cold pipe.Cjmartz2k wrote:No reason to upgrade the intake manifold for anything under 500hp
I understand the differences and how psi is a useless way to compare, but considering the small turbo of the RB, its displacement, restrictive looking manifold, etc, it's just surprising to me. I thought may have to push closer to 15psi with all factors considered.RustspecS13 wrote:PSI is completely irrelevant comparing different setups like that.marshallpre1 wrote: Just 12 psi? Really? That's pretty good. My stock Supra dynoed 302whp with stock twins at 11psi.
3L twin turbo pushing 11 psi is completely different then a 2.5L pushing 12psi.
PSI is pretty much a restriction to flow essentially. Bigger displacement likely means less restriction, or the turbo compressor will build boost completely differently. Especially twin vs single.
If you really just want 270-300whp your best bet is to get a steel exhaust wheel/shaft in the stock turbo. Good response and very durable.
And the tune is the biggest part, most people just do bolt on and hope for 275whp and a tune always helps.
~Alex
Thanks for the input, it looks like AEM didn't make an RB25 drop in for their V1. I know they sell one for V2. Also, where do guys mount your oil cooler?WhatsADSM wrote:A used EMS of some sort you can probably pick up for under 1000. Like a PFC or *maybe* and AEM.marshallpre1 wrote:
Otherwise the most cost effective would be a Nistune type 2 board + a Z32 ECU and a consult cable. But that definitely requires the most work. Since you will need to change about 5 pins to repin for the z32 ecu, and would need to solder in the type 2 board.
