Looking to get some springs
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
tarzan1669
Car: 2005 Infiniti G35 Coupe
So I am on a mission to lower my car! Coilovers are too expensive for me so I'm looking for some good springs. Any recommendations?
arrow23
Car: 2008 Infiniti G37S Coupe
Stillen Gen 3 CAI, HFC's and Gnd Kit
ARK Grip CAT Back
Hotchkiss Sway Bars
Eibach Pro Kit
GT Spec FSTB
Uprev Tune
20 mm Wheel Spacers
Stillen Front Lip Spoiler
Eibach Pro Kit.
The rear are easy to install.
The front, you have to remove the spring and shock assy. I then took them to NTB. They charged me $80 to remove and replace the springs.
It lowered my G about .75-1.0 inch.
No Camber Kit is needed, but you may want get get an alignment after a few weeks.
While your at it, put on Wheel Spacers. I put on 20 mm front and rear.
The combo looks great !
tarzan1669
arrow23 wrote:Eibach Pro Kit.
If I do get a Camber Kit would I still need to go in for an alignment?
I'll definitely give this a try! Ive heard good things about Eibach. I'll be posting pictures in the future
audtatious
If you get a camber kit you would need to immediately get an alignment. You don't want to run long with a toe issue or you will be replacing your tires.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
