What type of welding are you looking to do? I use smaw on all pipe sizes and all positions going downhill. Depending on the company and what you are doing you can make a good living. An average pipe welder that is employeed by a pipeline company such as "Buckeye Partners LLC" will probably make in the 50k range. but thats average. If you are better than an averaged certified welder the skys the limit. I know welders making 6 figures in the pipeline industry but they are older and getting ready for retirement. its time for us young kids to take control. If you work at it and do your ablsolute best on every weld then you will easily live very comfortably. you want companies looking for YOU. that is how you "survive" in this business. Its all about patience. it wont happen overnight for sure but it will happen if you are determined. Im still new to the business and im not a master of the art either so I still have alot to learn as well. Just passing to you what ive learneds14Geoff wrote:what does a pipe welder make around if you don't mind me asking? I'm going to school for welding and am just curious of the career and money possibilities
I could be wrong, but it seems like you are using the word "penetration" when you should be using "heat affected zone"(?).metalmagician wrote: Feel free to correct me if I get something wrong.
Penetration would be a function of heat settings on the welder, which is basically amperage going through the wire. The more amps, the more penetration. I could be wrong though. For all I know, Flux-core has the highest penetration efficiency... meaning it can penetrate more per given amp, although that seems to contradict the heat affected zone theory hametalmagician wrote:Flux core is basically mig welding that shields itself instead of using gas. It has the most penetration
I have. The hardest part about welding aluminum is its hard to tell when the metal has gotten too hot to keep its form. Unlike steel aluminum takes heat very well and spreads the heat transferred from the welding process all around the piece.then it gets too hot and a large area around the weld starts to fall. Where as if steel gets too hit while Welding you blow through in the concentrated area.AZhitman wrote:AWESOME thread!
I'd also like to learn more about welding aluminum... like, say, 1/8" thick sheet stock (diamond plate)... who here has done it?
What I mean by penetration is how deep the weld bonds the metal. Where as heat affected zone is the area where the heat changes the metals properties. It is best seen when welding stainless steel. And yes you are correct about flux core being the highest in penetration efficiency. Thanks for the correction though you are completely correct in your statementPapaSmurf2k3 wrote:I could be wrong, but it seems like you are using the word "penetration" when you should be using "heat affected zone"(?).metalmagician wrote: Feel free to correct me if I get something wrong.
Interesting. What's it done with? Can you MIG it?metalmagician wrote:I have. The hardest part about welding aluminum is its hard to tell when the metal has gotten too hot to keep its form. Unlike steel aluminum takes heat very well and spreads the heat transferred from the welding process all around the piece.then it gets too hot and a large area around the weld starts to fall. Where as if steel gets too hit while Welding you blow through in the concentrated area.AZhitman wrote:AWESOME thread!
10-4. We're on the same page then. It makes sense, flux-core doesn't have any gas constantly blowing on it (cooling it down), so more of your amps go into penetrating the metal.metalmagician wrote: What I mean by penetration is how deep the weld bonds the metal. Where as heat affected zone is the area where the heat changes the metals properties. It is best seen when welding stainless steel. And yes you are correct about flux core being the highest in penetration efficiency. Thanks for the correction though you are completely correct in your statement
