I might sound stupid here but what is the plenum? I usually buy Chilton or haynes but couldn't find one for my J so I purchased a pdf off ebay. Much harder to read if you ask me. With less pictures too. I did have to take my baby into the shop because I heard air escaping and I was loosing some power to her. They said someone crossed threads when replacing the EGR valve and it would cost me around $420 to get it fixed. They did a temp fix and it hasn't come loose again but I don't want to give it the chance. I'm a fast learner and love to get my hands dirty but don't know my way around this engine yet. What, if any, other pieces could I pull off a T? and what's the best way to check out the transmission? More of a custom interior guy but love to learn new things. BTW I have 159K miles on her. Where to start?GerryO wrote:Then pull the plenum to clean/replace numerous EGR/vacuum related things, replace the spark plugs and possibly the fuel injectors, depending on how many miles they have on them.
New struts, along with springs and sway bars from a J30t should stiffen up the suspension some, but you should probably first check/freshen up the transmission, if you plan on pushing the car harder.
Dropping and cleaning out the oil pan is something I'd like to do, but haven't done yet.
Cool. Thanks and I appreciate all your suggestions. I'll be sure to do an overhaul of all the basic stuff before I jump into the mods. I really want to do it right and I've seen the feedback you guys have been doing on here so I know where you all are coming from. The only problem is this is an everyday car so whatever I do has to be done on the weekend or after work and can't last more then a day or two. How long does it take to do the timing? I don't know anyone around here really so I'd be doing everything myself. I have no problem doing that just need to know what's most important to start off with. Sorry to be asking so much but like I said I want to do it right and in a proper order. Thanks again for all your help. Guess I need to start getting a list together for the store LOL.yodawill2000 wrote:As GerryO said.Before you add any power do the Timing and accessory belts.Replace ALL fluids. (transmission, Brake, Pwr steering and the rear end as well as the obvious oil/filter change.I would also drop the transmission pan and replace the filter and O ring and put on a new pan gasket.Then there's the NKG Sparkplugs FYI The plenum is the intake .Not an easy task to pull but you will know your engine well if you pull it to replace all thats under it and also replace the Timing belt and TStat , water pump and camshaft oil seals.
Not trying to scare ya but you need to get the basic stuff up to spec before you think about HP Mods.
The factory manual is the only one that's available and it leaves a lot to be desired, in both its' small (every J30 came with one in the trunk compartment) and jumbo sizes. Good news is that the J30 engine is in many ways same as the 300ZX engine, and those guys are more hands-on, so there are quite a number of related how-to write-ups that can be found on-line. Learn how to pull codes too.smartbeatz wrote:
Any suggestions on where to get a kit to do my timing? Is this something I can do by myself? and can I trust ebay for a kit?yodawill2000 wrote:As GerryO said.Before you add any power do the Timing and accessory belts.Replace ALL fluids. (transmission, Brake, Pwr steering and the rear end as well as the obvious oil/filter change.I would also drop the transmission pan and replace the filter and O ring and put on a new pan gasket.Then there's the NKG Sparkplugs FYI The plenum is the intake .Not an easy task to pull but you will know your engine well if you pull it to replace all thats under it and also replace the Timing belt and TStat , water pump and camshaft oil seals.
