Blackmobile »
https://forums.nicoclub.com/blackmobile-u106210.html
Mon Sep 13, 2010 10:55 am
overlays can be put on yourself with the help of a friend, just be very patient and take your time, they tabke about/at least 1 hour per light if you want to do it correctly.
fogs are fine for an easy mod but it depends what kind you get. you can get fogs that have a seperate switch which you push through the firewall and into the cabin, or you can get fogs with an oem plug and get 2 relay harnesses. plug one relay harness into one fog and one headlight, and plug the other harness into the other side, then your fogs will come on whenver your headlights come on. just make sure your fog lights are the same plug as your headlights, which oem fogs are.
