I had already posted and gotten through some info about one Z that I am looking at specifically.
Here goes:
facesmelt wrote:http://newjersey.craigslist.org/cto/3037323658.html
What do you guys think about this? The kid who owns it is a bit full of himself to say 600+ HP... That build might make 400-450 with good dyno tune. At least, that's what I think.
I'm planning on buying this car within the next week or so. Seems a bit pricey, but I could always give him a lower offer? I was thinking like $6-7000 ish.
I took a ride in it once and my friend test drove it, we both confirmed that it wasn't pulling as quickly as it should at all. Felt like it might have 250whp MAX. I'm hoping it is just a boost leak somewhere and I could get some money off the price with something that is potentially a pretty inexpensive fix. Boost came in WAY late, peaking around 4500-5000K and didn't go as high as he said it would (said it was tuned for 21 lbs but it probably didn't go above stock)
If i could get any good opinions on it, I would appreciate it. I'm gonna have another Z owner come with me tomorrow to check it out again.
Thanks
-Dan
facesmelt wrote:Yeah I know the power claims are complete bullsh*t, but that's not why I was interested in the car in the first place. But still, with the amount of work put into it, I see potential for a good 400whp with enough boost.it wont make 600 even on race gas but it does look like someone put a good bit of work into it, also that front end is not JDM that's the Twin Z version 1 which is no longer available afaik. before pulling the trigger id get it compression and leakdown tested at the least, its a bit of a gamble buying a vehicle with an apparent problem and not knowing what exactly it is, you may end up dropping 7k on a car that needs rings or a head gasket. That being said, if it is indeed a boostleak or some other small issue 7k is a good deal for this one, it needs some love in the tail department but overall it looks pretty good.
I mean, I definitely value your opinion and am grateful for the advice. I've heard of a compression test, but never heard of a leakdown test. How would I go about having this done on someone else's car though? Wouldn't I need to bring it to a mechanic's shop?
Thanks for the info on that front bumper, I knew it wasn't a Z34 style whatsoever (Or "JDM" for that matter) but I couldn't find exactly what it was. I'm just happy it's really not TOO riced out. You can't tell in the pictures but in some decent daylight you can definitely see that the front and rear bumper were not paint matched that well. I've heard the white is particularly hard to match though.
Also I'm not a fan of some of the things he has done to the exterior. Luckily, those are not actual aftermarket taillights, and it is just an overlay with the OEM stock taillights underneath.
One other thing that hasn't been sitting well with me is that it seems to me like he wants to get rid of it pretty quickly. He is so lenient on the price. He started at $11,000 and dropped to $9,000 the next month, and I know for certain he will let it go for around $7,000.
I've run the Carfax and in all 22 years of this car's existence there really isn't a hiccup that's been reported wrong in it's history, which definitely makes me feel at least a small amount better.
I'm hoping to enter as a new member to the Z family, I'm just treading lightly for the time being. All your help is appreciated.
Thanks
-Dan
facesmelt wrote:I will be sure to do so just as soon as the title enters my hands, thanks for the welcoming words!300ZXttZMAN wrote:Welcome Dan!^
When you buy your Z make sure you make an intro thread!
Alright well it turns out he can't even meet up today. And now his parents "have to think about it".NolimitZ32 wrote:A leakdown is done by removing the spark plug, setting the cylinder to TDC and pumping it full of air using a leakdown gauge set to see if there is significant pressure loss, this will tell you the general condition of the rings/HG/Valves as well as point to where the problem is if there is one and yes unless you have a leakdown gauge and air compressor handy you will need to take it to a shop. Remeber carfax only reports what was reported to the authorities or insurance. Your best bet is to A) find a reputable shop that knows Z32s and pay them to inspect it or find a knowledgeable Z32 owner or enthusiast in your area and offer him/her some pizza and beer, money, women. . . . men, sexual favors, or whatever else he or she is down for to go with you to inspect the Z thoroughly. If you fill out your location and other pertinent info we may be able to point you to a forum member that may be able and willing to help.
P.S. be weary of any car with an SAFC, piggybacks like this one alter timing when making changes to the fuel, this sometimes causes detonation and pre-ignition problems which ultimately results in spun bearings, bent rods, or cooked pistons. (all of these will show their ugly head on a proper leakdown test.
I guess when I return from vacation, I will have to make an appointment for a shop to do a proper leak down or compression test to make sure everything is in good order.
Is there any possibility of me getting a good confirmation that everything is all good compression-wise, if I end up NOT getting the compression/leakdown test?
Like is there any symptoms or things I can look for that can confirm it without having to go through the extensive test?
I spoke to two local mechanics and they've said that a test like that for one of these cars is actually pretty involved because of the massive engine bay clutter and that it could be cost up to $150 (1.5 hours labor) just to get this thing checked. It's not that I wouldn't spend the money to make sure everything is sound with the car. But if it DOES end up having bad results, that's going to be almost $200 (Compression Test + Carfax) I've spent to check up on this car and I won't even be buying it at that point.
I hope I don't come off as someone looking to skip corners, but it just seems like it has a potential to be very expensive and get me no where.
EDIT: Okay I've realized that I'm in some ways thread-jacking here, is there any place where questions like this would be more appropriate? Sorry, I just don't know my way around these forums just yet and really needed some quick information.
Thanks
-Dan
NolimitZ32 wrote:Dan, make a new thread, itroduce yourself and continue this convo in there. for the time being took at it this way, you spend $200 (which sounds a bit high but not outrageous for a compression and leakdown) on the front end, find out that the rings are cooked or a ringland is broken and walk away, you are $200 out of pocket. OR you don't spend $200 buy the car and within a few months your car is going through oil like a hillbilly through a meth stash and you end up getting the test anyway, spending the $200 to confirm that you now have to spend in the neighborhood of $2000 for a rebuild. $200 is very cheap to keep from making a $7000 mistake.
Rager wrote:hey dan welcome to NICO. first I would run as far away from that car as fast as possible.
1 the front bumber doesnt have turn indicators so its not legal and you would need to get a front bumber with the turn signals
2 the interior is horrible IMHO
3 unknown issues with the car that can cost you lots of money and head aches
4 the sells sounds like a kid to "need parents approval "
keep looking man and reading about this car everyday on NICO . and thank me later.
now this is a TTZ that you should look into getting
http://hartford.craigslist.org/cto/3129177842.html
Okay so I've read through all of this and have kept in contact with the kid selling the Z I originally posted about. It's actually a little more complicated than it seems on paper.
First off, yes he is a "kid". He isn't really into cars and just comes from a family with some money so he bought the Z with a lot of work done to it and was probably overwhelmed with just how in depth maintaining one of these cars could be so now he wants to get rid of it. Before this car, he had a brand new Scion TC which I have heard he ended up totalling and then a brand new Eclipse which I have no idea what happened to. But in the end, he is only 19 years old. But I am also only 21 years old.
Now this all leaves me at a disadvantage in some ways. Because since he isn't knowledgeable, he doesn't know anything about what is wrong and can't really answer any of my questions well. It's annoying.
Getting to the other points that Rager made...
1 the front bumber doesnt have turn indicators so its not legal and you would need to get a front bumber with the turn signals : Yes this is true, but that is the least of my worries as that is really pretty easy to fix. Whether I trade back to a stock bumper or just find some way to mount signals on this one.
2 the interior is horrible IMHO: To each his own, I personally never liked the all red interior that these can come with and think that this one is at least slightly better looking and tolerable to say the least.
3 unknown issues with the car that can cost you lots of money and head aches This is what's got me. And that's why I cam looking for advice. I'm now pretty heart-set on determining whether or not this car really has a serious problem or not. Because it will be a deal breaker for me. If it doesn't hold compression or has any serious engine problems, then I won't even bother offering less to make up for the funds needed to fix it, I don't need that headache now and I'm not looking for a project. But if it doesn't have any problems aside from the seemingly obvious boost leak, I think I found a steal honestly and would love to own it.
http://hartford.craigslist.org/cto/3129177842.html[/quote]
It's not that I don't realize that there are nicer Z's out there. It's that we are talking about a car that I could possibly be obtaining for literally half that price. Even if I wanted to, I don't actually have the money right now to purchase that other Z, as gorgeous as it is. Believe me, I've looked into some others, but my funds come up short so this one seems to be where I am sitting.
And here is where the situation actually gets difficult:
I have $6000 in the bank right now.
I have two cars sitting in my driveway, I need to get rid of one of them to justify buying the Z.
I have my DD 1995 nissan altima that I picked up for 200 dollars and is honestly not worth much more for me to sell.
I have my Jeep which has about $4000 in suspension work/tires/wheels and is really where I'm looking to make some money towards my next car.
This kid actually WANTS the Jeep. AndI bought the Jeep as a COMPLETE steal for $1500 over a year ago. But I'm not too sure how much it is worth now anyway.
The kid is willing to trade that Z for the Jeep + $3000 on my side.
I am having trouble selling the Jeep for any cash amount that would equate to me being able to buy this car for this much. Because it really an enthusiasts car. Since it's big, it could be inconvenient and since the paint is a kinda shoddy in some areas, it's not clean enough for someone to justify buying it as a DD road car unless they REALLY were into that lifted scene.
Few more questions/points to get to:
1. I see that some people pointed out that it wasn't originally a TT. Does that really affect the price at all? I mean it's a JDM TT engine in the end along with the transmission. Would you think that would hurt me on the re-sale side of this, down the road?
2. What price would you pay for it, if everything turns out fine with the compression/leakdown tests?
Thanks for any help you could offer, I realize this is an EXTREMELY long read!
-Dan
