looking to boost
All things Altima Coupe.
kball09
Car: 2009 altima coupe 6mt black
i decided i want to turbo my a/c not sure how much boost the stock motor will hold and looking for 300+whp will my clutch hold up or will i need new clutch btw 3.5 if soo where can i find one and is there a lightweight flywheel out yet too what kit is the better kit to get out of them all
thanks for the help
QR25DE
Car: 2009 Altima Coupe 2.5L 6MT Turbo
kball09 wrote:i decided i want to turbo my a/c not sure how much boost the stock motor will hold and looking for 300+whp will my clutch hold up or will i need new clutch btw 3.5 if soo where can i find one and is there a lightweight flywheel out yet too what kit is the better kit to get out of them all
thanks for the help
1. Read up on the turbo you are going to buy. There are different size turbos so saying "5psi" means nothing. Your goal should be possible, just keep in mind that the bottom end of that motor is the weakest link. It will go kaboom if you give it too much.
2. Spec Clutch makes clutches and flywheels for our cars.
The stock clutch will be good for awhile, but WILL die soon enough if you're hard on it.
Ranga14
Car: Boosted 08 Altima Coupe 3.5
The engine can handle up to 450whp... As for the clutch, as QR said above, you'll eventually want to get an aftermarket one but the stock should be ok for awhile as long as you aren't too hard on it.
