That's what we promote here, knowledge share. Here goes:KlrSpz wrote:I'm currently an Accord owner, and like it alright. I have a CAI and GReddy exhaust, some koni's and eibach's for suspension.... It's a pretty decent ride... But it's only a 4cyl.
So I'm thinking of getting an Altima 3.5... i havne't decided between the Coupe or the Sedan, so I'm posting here first.
I have some worries though, now that I'm more educated in cars, that I might buy a dud? The Accords had some well known problems amongst generations, and I happened to luck out and get a newer generation that fixed a lot of the more costly issues.
So obviously, I have some questions... I'd much appreciate it if people would chime in to let a buyer understand what he's getting into.
In general the latest models with the DR25 and VQ35DE have a solid history of reliability. The 2.5 is easier to work on in general, the VQ is well documented and has a pile of awards over the years. My experience is that Nissans (in general) are easier to work on. (And, yes, i've owned Honda's before). The head gasket problems were often a problem in the gen 1 sedans from what I remember (Which had a number of issues being a first model platform).KlrSpz wrote:I've read among the older (2002 and older) Altima's, there were issues with the engines... i couldn't find out exactly what, seemed to be more of a head gasket that would crap out frequently? Seemed to be getting a lot of radiator fluid in the mix, which obviously is no good to an engine. Is this a problem still?? If possible, how difficult is it to change the head gasket? Some cars I've had were cork gaskets, some metal, and some were black RTV (vulcanizing silicone).. Some I had to just unbolt 2-3 bolts and some valves and et voila.. on my accord it's apparently a PITA to get to... luckily i haven't had the need to yet..
The CVT seems to be holding up so far, since they haven't been out for long (Other than in other models like the Murano) it's hard to tell right now. The CVT is an auto transmission without gears. Gears are replaced by a variable ratio pulleys and band. as far a swapping fluids, dunno. Anybody out there got any ideas?KlrSpz wrote:Transmissions... This one is a doobie for me, as it's just about the only repair I won't do (aside from an engine overhaul). CVT's... any known problems? Do they have any issues yet? CVT is just automatic right? they don't have anything like that for manual trannies? (Still learning about transmissions)How difficult is it to clean the filter (if there is one)? How difficult is it to swap the transmission fluid (notice I didn't say flush)? I found a post on changing the MTF, how different is changing the ATF? Again, coming from the Accord it was only slightly different where you filled, draining was identical... The MTF change looks identical to that of the ATF change on the Accord.
The CVT transmission has a manual model for 6 simulated gears. IMHO they are too closely spaced on the RPM band. But you get 6 distinct gears in the manual mode. I've only heard some rumblings that the manual transmissions on the 08 models are a bit touchy. In general, I know that most who have the manual models love them (Especially, when considering matching them up with a turbo). As for reliability, Nissan manuals have been good for years, IMHO about middle of the road for maintanability.KlrSpz wrote:My Accord is my first automatic, and I'm contemplating going back to a standard... How are the clutches on Altimas? Good life-span for the master cylinder? (and if it's decent to not good at all, how difficult is the repair). Do the auto versions have "tiptronic" functions on the shifter for more gear control? (Accords only have D1-D3, which is better than just a D3, but i don't like how it feels).
So far, issues with the brakes have been limited to a couple experiences as far as what I have seen on the forum. There have been no recalls on the brake system from what i've heard for any of the models (Sedan or Coupe for '08). I park on a slope and have had no parking brake roll on mine. I have the CVT for reference. There have been a couple threads discussing brakes fboth on the positive side and the negative. In general, my experience has been that they're just fine for a daily driver, if you're going to go racing regularly then an aftermarket set would probably be important. I personally want to go slotted and cross-drilled eventually, but i'm not going big-brake kit.KlrSpz wrote:Brakes/Rotors... Do they have any issues? I've known other manufacturers to have crappy rotors that warp often, and brakes that don't last for crap. Is a Brembo and Hawk HPS combination positively revered for Altima's like other imports? I also read something about (and this was AT and MT transmissions) the Altima Coupes (i think i saw it abbreviated as A/C?) still roll when parked and e-Brake on????? In a standard I always leave it in first, so this might not be that big of a deal if i go with that, but if i get an AT, then I don't want to have to worry about this.... that's scary...
You may need to look on the Interior/Exterior altima forum ofor information on this. I have no idea. Anybody out there have an opinion?KlrSpz wrote:Radio dash kits... For the accord, they are way over priced... $150+ for a decent kit, and it still sucks... It looks better than the alternatives, but it cost more than my JVC headunit with USB playback!!!!! What are the options, and how easy is it to remove the dash pieces to achieve this? A Custom head unit is essential in my cars... Speakers/Amps - not so much, but I'll probably get into that at a later point.
There are plenty of WAI solutions available now, most on the forum have gone Injen or Stillen to date. All models of the Altima ('08) have MAFs.KlrSpz wrote:I'm certain of this, but if someone could speak to it for my assurance I'd appreciate it: - CAI or SRI/WAI? Easily available? Do you guys buy the $250+ units from AEM/Injen/etc or do you get the ebay specials and slap on a K&N filter? Do the Altimas ALL have MAFs? Most Accords don't outside of Cali.. - Suspension -- This time I want coilovers; independent suspension components are a PITA to me... What's a good brand/configuration?
Essentially, Identical in features, but the body is almost completely different. Coupe and Sedan only share a hood from a body panel perspective but that's about all from what I can tell. Sedan has more space, 2 extra doors, and a variety of other small differences (i.e. Tail Lights). The all come with 4 wheels on the ground.....KlrSpz wrote:Do the coupe's have any components that the sedan doesn't? Coming from the Accord world, they are identical except a few measurements here n there...
This is your only free ride on the forum, prepare to be flamed for non-searched questions....KlrSpz wrote:I realize that I can search for most of these things, and have been... I just don't want to revive an old thread, and would like some current feedback.
Thanks in advance for the answers...
-Spaz
Yeah, that's common... first models are just that... And that's interesting to hear that Nissan's are easier to work on... Crap that reminds me i think i missed a local nissan meet - wanted to see the bay in person of a real owner.windhaven wrote:In general the latest models with the DR25 and VQ35DE have a solid history of reliability. The 2.5 is easier to work on in general, the VQ is well documented and has a pile of awards over the years. My experience is that Nissans (in general) are easier to work on. (And, yes, i've owned Honda's before). The head gasket problems were often a problem in the gen 1 sedans from what I remember (Which had a number of issues being a first model platform).
OK, guess I have more research to do on CVT's... the band part sounds like it might be a maintenance part to look into.windhaven wrote:The CVT seems to be holding up so far, since they haven't been out for long (Other than in other models like the Murano) it's hard to tell right now. The CVT is an auto transmission without gears. Gears are replaced by a variable ratio pulleys and band. as far a swapping fluids, dunno. Anybody out there got any ideas?
That's good to hear.windhaven wrote:So far, issues with the brakes have been limited to a couple experiences as far as what I have seen on the forum. There have been no recalls on the brake system from what i've heard for any of the models (Sedan or Coupe for '08). I park on a slope and have had no parking brake roll on mine. I have the CVT for reference.
Yeah I think I'd go with WAI this time... the CAI is a pita to maintain... I've been meaning to take the bumper off to clean it lately...windhaven wrote:There are plenty of WAI solutions available now, most on the forum have gone Injen or Stillen to date. All models of the Altima ('08) have MAFs.
OK this is actually really disappointing. I have the Eibach Pros and Koni Yellow (adjustable dampner) for my Accord. And while i love the Koni's, I really don't like my car being lowered by the springs... I can't even go over a coke can without hitting it... I scrape bottom ALL the time around here.windhaven wrote:No coilovers available yet for the latest models, most on the forum have installed Eibach Pro Kits, Stillen Rear Sway Bars, and Raceline End-Links for suspension mods.
What about in the bay [components and size] and transmission?windhaven wrote:Essentially, Identical in features, but the body is almost completely different. Coupe and Sedan only share a hood from a body panel perspective but that's about all from what I can tell. Sedan has more space, 2 extra doors, and a variety of other small differences (i.e. Tail Lights). The all come with 4 wheels on the ground.....
The CVT's are meant to hold up for the long haul - my dad works for a company that makes the transmission fluid (it's called "N-2") and they worked directly with Nissan when they were building the xCVT. While it does sound like the CVT would be prone to failure and such because of the constantly changing drive belt, they are built extremely durable and as long as they are maintained properly, they will give you no problems.windhaven wrote:The CVT seems to be holding up so far, since they haven't been out for long (Other than in other models like the Murano) it's hard to tell right now. The CVT is an auto transmission without gears. Gears are replaced by a variable ratio pulleys and band. as far a swapping fluids, dunno. Anybody out there got any ideas?
Which filter are you refering to? Oil, air, cabin? The oil and air filters are relatively simple to do by yourself, the cabin is a b***h to do because it's right next to the glove compartment.KlrSpz wrote:How difficult is it to clean the filter (if there is one)? How difficult is it to swap the transmission fluid (notice I didn't say flush)? I found a post on changing the MTF, how different is changing the ATF? Again, coming from the Accord it was only slightly different where you filled, draining was identical... The MTF change looks identical to that of the ATF change on the Accord.
Both my VW's, as well as the Saturn, and my 4Runner all had RTV for the head gasket... I hated it... It was a ***** to clean, never again....Sucks to hear that it's not easy to fix.... hmm...Scandinavian Flick wrote:first off the VQ engine like windhaven said has been winning awards and is an outstanding motor, i havent heard of any headgasket problems yet. by the way ive never heard of a car having a rtv silicone head gasket. anywho in the event the headgasket goes bad on either side, due to the motor being transversly mounted it would be an incredibly difficult task.
What exactly do you mean "leave it alone"?Scandinavian Flick wrote:2nd, as for the CvT transmission, just leave it alone its a good transmission, windhaven even explained it well, but its not nearly as good as the manual, the 6speed has a wonderfully smooth clutch, id definately go that way.
OK so what does it mean to be maintained properly? I've read in a few places there's almost no maintenance to be had, minus the fluid swap. And even that's at every 15k miles?marlin29311 wrote:The CVT's are meant to hold up for the long haul - my dad works for a company that makes the transmission fluid (it's called "N-2") and they worked directly with Nissan when they were building the xCVT. While it does sound like the CVT would be prone to failure and such because of the constantly changing drive belt, they are built extremely durable and as long as they are maintained properly, they will give you no problems.
Why not? I've changed transmission fluid on all my cars... And I will -----NEVER----- do a flush on a transmission.. I've seen at least 10 trannies die from a flush performed by dealers. The concept of a flush is generally bad for trannies, however the CVT may be different... Having said that, I usually do a drain-n-fill 2-3 times with 10-15 miles in between.. it's not a 100% fluid swap, but it's pretty damn close...marlin29311 wrote:As for changing the fluid, this isn't something that you can do on your own or bring it to your local Midas, Jiffy Lube, STS, etc, to do. You CANNOT (note caps) use a standard automatic transmission fluid in the CVT or your will damage it. With that said, the only bad part about the CVT is the $200 you have to pay to have a fluid flush...
Hmm never really thought of trunk space... The accord has a HUGE trunk in my coupe... huge... 5 dead bodies easily.marlin29311 wrote:Exteriorly, as windhaven said, the only things that the coupe and sedan have in common are the hood, the headlamp housings, and the 2.5SL sedan has the same wheels as the 2.5 coupe. Other than that, I can't think of anything else that is similar....go with the coupe!...unless you need a lot of trunk space (i can fit 2 golf bags in the coupe with a little room left over)
OK, wasn't sure if knocking would cause any damage.marlin29311 wrote:The 3.5SE takes 91 octane or higher, the 2.5 takes 87...(but you can use 87 in the 3.5SE - you just lose power, gas mileage, etc)
Well at that point I was referring to the transmission filter/screen/etc.In my Accord teh cabin filter is behind the glovebox, you just move 2 tabs aside and the box ffolds all the way down, and behind it you gain access..http://www.youtube.com/watch?v=gFHUJJ6Rc6s -- for reference.marlin29311 wrote:Which filter are you refering to? Oil, air, cabin? The oil and air filters are relatively simple to do by yourself, the cabin is a b***h to do because it's right next to the glove compartment.
You can get a factory dash kit for a double din stereo from the Nissan dealer or online for about $30.KlrSpz wrote:Radio dash kits... For the accord, they are way over priced... $150+ for a decent kit, and it still sucks... It looks better than the alternatives, but it cost more than my JVC headunit with USB playback!!!!! What are the options, and how easy is it to remove the dash pieces to achieve this? A Custom head unit is essential in my cars... Speakers/Amps - not so much, but I'll probably get into that at a later point.
