I have a 92 engine AND harness in my 94, but I have FSM's for both and I now have a spare 94 and spare 92 motor (to boost and built/boost for my Datsun). I will look at the 92 CAS versus the 94 harness, etc.
As I understand it, the one car has two connectors on the CAS. One for the cam angle sensor and another one for the "sub-cam angle sensor" for use when the cam angle sensor fails (not sure how often that would be). The other CAS has the connector for the cam angle sensor and a >>pig-tail<< and connector for the exact same second sensor. It simply runs about 10" over to the front-center of the engine to connect to the engine harness. I don't expect it would really have a problem either way; just run a couple wires over a bit, etc.
I really don't understand why everyone is so leery that they won't work. I would expect an SR20 CAS would work if the bolt pattern lines up. Nissan uses the same stuff on everything. Heck, my 77 Datsun uses the same crazy throttle sensing stuff that is on the VH45DE. Likewise, I grabbed a TPS from a J30 with the VG (or whatever) and it works on the VH45DE as well. The only real different to my eyes is the length of the pigtail, etc.
Not sure what stuff is different on the ignition. I have a set of harnesses for both. I know the cars with TCS have extra crap on them. Maybe the connector type is different but pulling pins or resoldering wires is easy enough. Did you find the FSM's OK?
BTW, email me at
[email protected] for faster response.
