Looking for Type X motor harness (J4 ECU)Can I use regular s13 harness?
schanne
Car: 93 Hatch-Sr20
I'm getting the ecu and motor rewired and done right. The best thing at this point is to get a new harness (because mine is all cut up). The cheapest one I've seen brand new is 200. on ebay, and 350. on frsport. Does anyone know a better place to get them from? And will that harness work with the Type x blacktop?
SpeedRacer1
Car: 1990 240SX, G35
It will need to be rewired to work with the J4 ECU.
schanne
Car: 93 Hatch-Sr20
So should I just buy the one thats OEM SR20 S13 from E bay for 200 bucks?
jdm_master_X
Car: 92 Nissan 180SX LHD!...LaWL
if you plan to run the E5 ECU on a J4 harness you will have to do some repinning as well.
schanne
Car: 93 Hatch-Sr20
The J4 pinout diagram I have seems like its missing some wires. Do you guys have a better one? I have the one speedracer put up a while back.
The pinout diagram on the S14 FSM is different from speedracer's. Is it supposed to be different because its the S14?
Modified by schanne at 7:13 AM 11/29/2007
schanne
Car: 93 Hatch-Sr20
Here's the wire harness I'm looking athttp://cgi.ebay.com/ebaymotors...wItem
SpeedRacer1
Why would the S14 FSM have an S13 J4 pinout? The 1993-1996 S14 ECU doesnt even have the same plug as the J4 ECU. The 1997-1998 S14 ECU has the same plug and some similar wires as the J4, but I never released the pinout for that ECU.
The wires that are missing off the diagram I made are wires that are not used in the swap. Everything you need to rewire the J4 ECU to a 62 or E5 SR harness is in that diagram.
schanne
Car: 93 Hatch-Sr20
speedracer, your the bomb digity! Thanx for all your help...
