Looking for throw away parts.
94Q45Beast
Car: 1994 INFINITI Q45t w/HICAS
1992 INFINITI Q45
2017 INFINITI Q70S AWD BLACK ON BLACK
I'm looking for 2 old used, ready to throw away OEM shocks or tokico's ....one front shock with top and bottom mount and one rear shock with top and bottom mount, including springs.....for the 90-93 Q45, 94-96 Q45, Y33's, and F50's........assembly cannot be deformed. first person will get to test and purchase the new shocks specially engineered and manufactured for the Q before product release date at a special discounted price, you will have a choice to get your hands on one of 3 kinds of shocks, and will be the first person to get your hand on them. AND be the first person to get your hand on a High Performance Racing brake kit consisting of European racing style calipers and rotors specially designed for braking at intense speeds at a special discounted price specially engineered for the Q....all discounts are only for those first people.
Shocks to Choose from:
1 : Twin-tube Two-way adjustable(separate adjustable Compression and Rebound) shocks and can be applied to all types of road/track
2 : Every day general road shocks
3 : racing shocks.
94Q45Beast
1992 INFINITI Q45
I don't think I was clear enough, you send you old shock assembly in, and get a generous discount on the new shock assembly, for all generation Q's. with your choice of suspension......same with the brake kit.....except there is no need to send in you old ones, the brake kit has a Rotor size of 304mm X 26mm, Medium 6 piston calipers with interior piston dirt seals with a rotor design of your choice, between smooth, drilled, slotted, drilled and slotted. The brake kit includes....
(2) 6 piston caliper
(2) 2-piece Rotor (with hat) with a rotor design of your choice
(2) Set of Caliper mounting brackets
(2) set of brake pads
(2) Brake lines
Hoses are in the testing phase and will be available soon.
