EazyBreazy »
https://forums.nicoclub.com/eazybreazy-u10672.html
Fri Feb 29, 2008 9:59 am
the real thing is what do you plan on doing with the car, why must you have over fenders, is there fender damage on the rear quarter panels that cannot be repaired in a cost effective manner. what are your goals for the car, are you going to track it, or just drive it on the streets, is it going to be a show car, drift car, all of this stuff should be taken into consideration.
Remember fiberglass does not do well when hit, ie road debris and stuff like that will generally cause damage to not just the paint, but the fiberglass as well, it is cheaper to replace, but less durable that the metal. If for your goals you can run stock fenders, do so and put as much wheel and tire under them as you can, it will be cheaper in the long run. Remember that individuality is somewhat overrated, and sometimes its better to do the minimum to improve your car than go balls to the wall with exterior modifications.
If you dont have the need for 10/11 inch wide rear tires because you will not be seeing any track time, or do not have enough power to even break a 9 inch wide tire loose, then you will wind up spending money on modifications you dont need as opposed to spending money on modifications that would be alot more beneficial to you
