Looking for the drain hole in the passenger side of the trunk (if there is one)
gailpearce
Car: 1995 240 SX SE
I found about 2" of water in the trunk on the passenger side of my 1995 240 SX SE yesterday. The location is in the very back of the passenger side of the trunk, there were some vents located right above the area where I found the water. I was wondering if there may be a plugged drain hole and if so, do you know where I should look? Thanks, G
nando
Car: 1995 nissan 240sx se
1989 nissan 240sx
there are several drain in the trunk...most are coverd by plasti pugs the range in size... there is also a drain on the outer most part of the trunk area...behind the wheel house...
my car had the same prob... and i found the water came from gaps in the tail lights where there had been some colision work done to the rear panel
hope this helps
good luck
