Looking for Tangalora 95 Q45 Fuel Pump Question
Walnuts
Car: 1995 Q45 with TCS 118K
Does anyone have a copy of the document (with pictures) that Tangalora created a while back when replacing the fuel pump? I read a thread discussion where the document was referenced but have been unable to locate a copy. I'll be replacing my fuel pump next weekend and thought it would be very helpful.
Thanks, Adam
DAEDALUS
Car: 1990 Infiniti Q45
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Don't really need the pictures. You will have to search the archives for each nissaninfiniticlub link. You do have an FSM, right? Plenty of posts on this topic.
Walnuts
Thanks Brian, Yes I have a FSM but this step by step doc is just what I was looking for. Wish me luck.
Adam
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Make it so!
Read my dumb a** comments also. The best thing is to look at the clips of the parcel shelf from the trunk and contemplate before releasing them. If you have an active or TCS model, some other electronic modules attached to the parcel shelf may have to be dropped. Be sure to have a new O ring, disposable cloth towels, and a 2Qt. container for the return line drain. Once the gasoline gets on the noise dampening material, is dissolves it and doesn't evaporate forever.
Be slow, be cool, and don't bend the fuel level sender on installation fo thenew pump. If anything is on the bottome of the tank, remove it, steam clean it, and blow out the metal fuel lines and replace the rubber ones. Replace the fuel filter also (inexpensive from Joe).
If I can do it, any monkey can.
Good time to vacuum behind the seats and R&R them with Lexol. Avoid saddle soap or any alkaline cleaner.
Walnuts
Thanks fot the suggestions. My Pump arrived on Saturday and I plan to pull things apart one night this week. I'll let you know how it goes. Thanks Again, Adam
Mr.Q45a
Car: 1994 Q45, 1995 Q45a
Hi,
The Tangalora pictures helped me when I replaced the pump.
I hope they will do the same for you.
Mr.Q45a
2 of 3
Mr.Q45a
3 of 3
control unit DIY
