Looking for suggestions on rotors
Velvetdew7
Car: 2003 Nissan Sentra SE-R Spec V
Ok, so I'm new here and I was just wondering what rotors seem to be the best ones on the market that will actually work for my car. I've heard that Brembo is good and I've gotten good reviews for power slot. I really want to go with slotted rotors, as I am installling ceramic pads soon and want to do it all at once since my front rotors are glazed and it appears that the rears are most likely not turnable.... thanks
FRSport
Brembos are good standard all around rotors. Even cheap rotors (set to oem spec) are fine for daily driving (I even use no names for autoxing & track events - cheaper rotors = you can replace them more often, hee hee).
What will you be using your car for? If just daily driving, no reason to go slotted... If you want slotted, you can still get Brembos that have been slotted...
