looking for stock struts
layenframe
Car: draggin frame in my sono
im looking for a set of 97 240sx rear struts anyone that has a set they would like to get rid of please email me:[email protected]
Dori Dori
Car: Cars of course
Go here, http://www.nissaninfiniticlub....id=43
There's always someone parting out a 240 in there. Good luck.
layenframe
thanks ill look there
Grant@tirerack
Car: Auto racing (AMLS, Cart,F1,IRL in that order), old show rods, classic monster and bad sci-fi movies,
We have the KYB GR-2s in stock at $53.00 each. Why mess around with used?
http://www.tirerack.com/a.jsp?...x.jsp
Nismo_Freak
Car: 89 Nissan 240SX
I'd suggest GR2s
Chingon
Car: 1991 and 1992 hatchbacks
maybe he's going koni inserts and his are rusted?
layenframe
im interested in the gr2s but will they work with a lowering coil or just the stock suspension????????????
Dori Dori
Car: Cars of course
They'll work w/ lowering springs better than old (or new) stock struts would. I wouldn't go too low with them though.
layenframe
it is lowered 3 inthe back 2.75 in the front pritty much hammeredall the fluid blew out of the struts recently and now it sways up and down like crazy the exhaust hits the ground. do the gr2s lower it anymore or keep it the same height as stock, i cant go any lower what is so special about them? are the adjustable dampening?
Chingon
no...gr2's although better than stock, are pretty much stock and not recommended for lowering. For that, it's advisable to get kyb agx or even better the one's i mention earlier koni "yellow" sport, both of which are adjustable and will fetch a pretty penny. Also, by lowering coil, I'm assuming you mean "high performance lowering spring", and not the usual lowering spring?, which I would not recommend using on anything.
Again, to lower the car and thus center of gravity, it will cost the $375 shipped for agx (currently on ebay, usually 390), or the higher alternative koni's (490-550) + some good lowering springs, like some reasonably priced espelir (150 ebay) or other higher priced.
layenframe
i dont have the money for that stuff right now, that is y im looking for the stock rear struts
BadMojo
Car: 2007 Mazdaspeed 3
I've got some GR2's on the front of my car and I'm gonna put a set on the rear too. I plan on matching 'em up with some Eibach Pro-Kit springs. We'll see how long they last. Hell, the GR2's are so cheap I don't really mind experimenting with them.
Got 'em from TireRack! :thumbup
Chingon
well, i'm just going from what i've heard, but I've also seen a couple of ppl run them on the boards w/lowering springs and run them hard for quite some time. So perhaps they do last. Also, many ppl run them on the isuzu impulse awd turbos as a coilover strut.
BadMojo
I'm thinking that something reasonably mild like the Pro-Kits, H&R Sport or Suspension Techniques springs should work out. I'm sure Eibach and H&R had OE strut characteristics in mind when they chose the spring rates for their products anyway. Since the GR2 are a shade stiffer than OE, I'm hoping it'll work out. I'll let ya know!
