D-Roll wrote:
Only if I knew then what I know now, I would of gone with 35mm offest rather than 48mm Well next time I get rims, I will get the right offset
Its not your fault homie, remember, none of us knew... Brian and I were taking a big risk getting the Eibachs being that we really didn't know if the springs, camber, everything would work well together... but as you see, they work perfectly.. again, this is how the cars should have come from the factory!
Sorry to get off subject, back top the issue of the spacers... I would actually say 8mm is the absolute furthest I would go if getting spacers... However, I do believe you can get extended lugs to place in your wheels, just not sure where you'd get em from!
