looking for some help with turbo rebuild
emperor_lunchbox
Car: 91 240sx, 96 eclipse spyder, and 96 camaro z28 (For Sale)
ok, i just bought another motor to build up for boost.Basically what I want to know is what parts are necessary to change out?I am building on a budget, I would like 300-325 hp reliably. I was thinking just getting new gaskets and a timing chain kit?The motor has 90 k on it.Any suggestions.My goal is 12.9thanks.
crzycav86
Car: 93 Nissan 240SX KAT
90k is a toddler for a ka as far as i'm concerned.
just check the compression to make sure it's in spec. then have at it.
If you want to play it safe, don't go over 350hp without a buildup.
emperor_lunchbox
what is the recommended compression specs?I think I read it somewhere, but I would like to make sure.Thanks.
Mishka
Manual says 178 psi is perfect.
