Looking for some friendly tire advice...
StevieRaySTL
Car: 1990 Infiniti Q45 w/ Nico ECU
1993 Infiniti J30 w/ x-flow
1997 Toyota Landcruiser
-- Got a set of M45 18x8s that are going on my 90 Q and I'm currently tire shopping. Would I be better suited with a 245/45 or 255/45? Just looking for some thoughts & opinions, especially from someone running this type of setup. Thx in advance, Nico is Nice.
qship96
Car: 1996 Infiniti Q45
I thought the M wheels were the wrong offset for the Q??????
Q451990
45mm on the 90-96 OEM wheel vs. 47mm on the 18x8 M45 wheel. The earlier 18x7.5 M45 wheels had a 35mm offset, so that's probably what qship is thinking of.
Heath
szh
Car: 2018 Tesla Model 3.
StevieRaySTL wrote:-- Got a set of M45 18x8s that are going on my 90 Q and I'm currently tire shopping. Would I be better suited with a 245/45 or 255/45? Just looking for some thoughts & opinions, especially from someone running this type of setup. Thx in advance, Nico is Nice.
Based on what the rolling diameter would end up, I'd say that 245/45-18 will be a better fit for the first gen Q.
Lots more tire options in that size too.
Regardless, since it is a first-gen Q, I'd still be concerned about fitment using the current-gen M wheels. The original OEM wheels were a lot narrower, etc.
I think that the 47mm offset of the wider 2006+ M wheels will contact the suspension components - the first-gen M with 35mm offset would be a far better fit.
But, the best idea is to try a fit at a friendly tire place - just wheels first and then with tires.
Z
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
245-45-18 is the ideal tire size on the Q.
DoinkMobb
Car: 1994 Infiniti Q45 Green/Tan
1996 Subaru Impreza 2.2L wagon
Stock tire size: 215/65/15 = 26.0" diameter245/45/18 = 26.7" - your speedo will read 2.6% high
I would go with:255/40/18 = 26.0" matches stock diameter-OR-245/40/18 = 25.7" - your speed will read 1.1% low
I have G35 coupe rims 18x8 on my '94 and I went with 245/40/18 because the tires I wanted were a LOT cheaper in that size and the speedo is only off by a tiny bit.
However, the G35 coupe rims have a 30mm offset, so I would double check that the 47mm offset isn't too high.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
There was a great tire sticky in Infiniti General.
Maybe Z can locate it for us.
Also a comprehensive wheel post in this forum that was effed up by careless VIP type posters.
StevieRaySTL
Thanks for the advice guys! Ill post a pic up in a while when I get them on. The injectors & chain guides should be done in a week or so. Thx again.
StevieRaySTL
They fit great, thanks guys. Sorry about the poor cell phone pics, my camera is out of commision. Nico is Nice.
BadQ45t
Car: '21 Nissan Leaf SL Plus (wife's car)
'05 Nissan X-Terra S 4x4
'97 Infiniti Q45t SOLD! Miss the old girl
'84 Nissan 300ZX (Original Owner)
'16 Mercedes Benz S550e V8 Power & 35 MPG
Very nice. Those must be 03' M45 Rims as the 06' versions need spacers on 1st or 2nd Gen.
Good score, great update on the car.
StevieRaySTL
-- Thanks! I believe they are off a 2006 M35x, got em on here from a guy in KC.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
qship96 wrote:I thought the M wheels were the wrong offset for the Q??????
The Y34 will fit, the Y50 will not wihout the additional dead weight of spacers.
paranoidjack
Car: 2012 Infiniti M56 S
2003 Infiniti M45
2001 Infiniti QX4
2000 Infiniti Q45
1998 Nissan Pathfinder
1996 Infiniti J30
Those look nice and meaty.
StevieRaySTL
-- Thanx
qship96
The wheels almost look too big for the car?
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
They look bigger than 18" for sure. More like 20"'
