Ok well I've looked over the Tips and advised suggestions you've given to me and I've managed to come up with a revised list hopefully to my benefit. As far as the wheels go and why I didn't change them is because I like them and there is really only 1 or 2 other types of wheels I really like... But here is my edited list let me know what you now think.
Turbo Kit: Greddy Bolt-on Twin Turbo Kit Nissan 350Z 03-04
http://www.vividracing.com/cat....html Waste-gate- Tial F38mm Wastegate Universal (Dual X2)
http://www.vividracing.com/cat....html BOV HKS Super SQV Blow Off Valve Universal
http://www.vividracing.com/cat....html Fuel Injectors- DeatschWerks 350Z 600CC Injectors http://www.rallysportdirect.co....html Eagle Rods- Eagle Rods http://www.prostreetonline.com...d.asp Forged Pistons Cosworth Forged Piston Set Low 96mm Nissan 350Z VQ35 03+
http://www.vividracing.com/cat....html Head Gaskets JHKS Metal Head Gasket 0.7mm Nissan/Infiniti 350Z/G35 03-05
http://www.vividracing.com/cat....html Head Studs ARP L19 Head Studs http://www.injectedperformance...=4436 Springs JWT Spring and Shim Kit
http://www.vividracing.com/cat....html Gauges- AEM Digital Turbo Boost Gauge
http://www.turboneonstore.com/...d=477 AEM Digital Oil Pressure Gauge
http://www.turboneonstore.com/...d=475 AEM Digital Oil Temperature Gauge
http://www.turboneonstore.com/...d=476 Pod-
http://performanceparts.com/part.php?partID=269140 Wheels- American Racing Muscle : rebel (Tire Rack.com) performance Black w/ Mach Lip Front• Offset: 25mm Backspacing: 5.94" Bolt Pattern: 5-114Rec. Tire Size: 245/40-18Weight: 25.5lbs. Rear• Offset: 30mm Backspacing: 6.65" Bolt Pattern: 5-114Rec. Tire Size: 265/40-18Weight: 27.0lbs. BBS RS-GT Diamond Black Finish Front• Offset: 20mm Backspacing: 6.18" Bolt Pattern: 5-114Rec. Tire Size: 225/40-19Weight: 23.0lbs. Rear• Offset: 25mm Bolt Pattern: 5-114Rec. Tire Size: 245/40-19Weight: Not Available Motegi Track Togue Black w/Mach Lip Front• Offset: 30mm Bolt Pattern: 5-114Rec. Tire Size: 225/40-19Weight: Not Available Rear• Offset: 30mm Bolt Pattern: 5-114Rec. Tire Size: 245/40-19Weight: Not Available
Exhaust- Turbo Tuned - EVOTT
http://www.greddy.com/products...ory=3 Clutch kit- NZ1-HDG6 (2003 Nissan 350z)
http://www.advancedclutch.com/...#2328 • Heavy Duty Pressure PlateClamps load increase of 20% to 50%, Pedal feels stock to moderate, Many SFI Certified to insure safety• Spring Centered (6 Pad) DiscRecommended for Road Racing and high power Street, Increased torque capacity and spline life, Very good durability and good spline life, Quiet operation, reduced driveline shock
Stroker Kit???- not needed Coil-overs- BC Racing coilovers NISSAN Z33 03+
http://www.eracingworks.com/BC....html Engine Management TurboXS UTEC Engine Management Nissan 350Z 02-06
http://www.vividracing.com/cat....html Wing/Spoiler- APR GTC 200 Drag Spoiler Nissan 350Z
http://www.modacar.com/product....html 3D Carbon Type 5 Carbon Fiber Wing, 03-08 350Z
http://www.thezstore.com/page/...-1869 Headers NISMO R-Tune Headers, 03-06 350Z
http://www.thezstore.com/page/...-6086 High Flow CAT-
