240sx2soon »
https://forums.nicoclub.com/240sx2soon-u26449.html
Fri Apr 22, 2005 5:13 am
Yes I know"SEARCH" , but hear me out anyway ( I'll read the sticky's when I have more time to sit in front of my computer). I recently came to the conclusion that doing an SR swap the way I want it done would be pretty damn pricey ( $8,000 notch top, all the power goodies, radiator, install auto to manual conversion and some other stuff ) so my next best step is to look at buying a low mileage KA24DE and fortifying it for boost. Here is the current plan: Use ARP rod bolts, main bolts and stud kit as well as a metal head gasket to keep it together under pressure. Replace timing set and oil pump ( good maintnance stuff while motor is not in the car ) and install a set of cams and adjustable gears ( I think I read somewhere that the early model KA cams were more powerfull). Boost it with a Greddy turbo kit and front mount intercooler ( I like it because of the price and the comprehensivness of the kit ) and add a type RS BOV and turbo timer. I am picking up the 5-speed transmission this weekend so the plan for that is stage two clutch and lightweight flywheel that will be used when the turbo KA goes in next summer. I figure that setup with good tuning should be good for around 250 to the wheels at 10 psi. Again, when I get more time I'll pour over the data in the sticky and on other boards but for now fire me back some info and comments, thanks.
