How much do you want for those springs? Do you know how much of a drop it is? I will be running 18" rims, but if possible can you estimate about how low it goes. Also I am willing to buy those springs from you depending on what amount you want, but seeing as they go for $300 im guessing you want around that. but if you can give me the specs on them that would be awsome. Oh how does the car ride with them? bumpy like cut springs? or more like a sports suspention? anyways let me know. I have cash, paypal, money order whatever.CrimsonQ wrote:I have an unused set of CC Springs on ebay now. If you want CC's I suggest you get em now Eibachs are no longer made, only found used.
http://cgi.ebay.com/ebaymotors...&rd=1
Look in the Infiniti Parts section. Look for the user popPop, he can get you a spoiler most likely. Coil overs?--not many are keen on that here.
So no one here runs JIC's??? IS that only because of the fact that customer service sucks? hmmm. what about hight wise? can Cali custom (CC) springs go as low as JIC or any other coilovers can? the car im building definitly is going to be more along the lines of a "Parking lot looker" IM looking for a pretty low ride hight, but not to the point where im dragging my oil pan off the car whenever i go over speed bumps. anyone have any tips or tricks on what they used for suspension for lowering?maxnix wrote:You'll probably prefer the unique rear parcel shelf for the t and a models also.
Beware of JIC. Reputation for customer service sucks. No one here runs them.
The general rule is to restore to OEM as new specifications, then modify. Otherwise you may end up driving a drag queen in need of a serious operation or transplant. Read Q45tech's post on springs and suspension, unless you just want a parking lot looker.
Mike, how comlpex of a task was it? Are there any additional parts one should look for when buying a used spoiler? I would assume you have to drill from the inside of the trunk lid, so getting the holes lined up with the mounting locations requires some precise planning....goody94q45 wrote:BTW- I installed an OEM spoiler (from PopPop) on my Q. The std Q trunk lid does have a connector ready to plug into the spoiler brake light. The template for spoiler installation is not available unless you buy the spoiler from the dealership. Measure carefully before drilling into your trunk lid.
