looking for power estimates...
USDM240
Car: 1993 Nissan 240SX Limited Edition 'vert
ill be doing a KA-T build here in the next few months and was wondering what kind of power i might make with this particular setup.
right now i have:
91 KA24DEJWT S1 camsA'PEXi N1 cat backcone filter and adapterno A/Cno P/Selectric fan
i will be installing:
KA-T exhaust manifoldGarrett/AiResearch T3 Volvo FMIC2.5" IC pipingSR 370cc injectorsRRFPRA'PEXi S-AFC300ZX TT fuel pumpMSD BTM ignition system
i will be running approximately 7lbs of boost to begin with. i wanted to get some type of estimate from some of you that have done a KA-T setup before. i have tinkered with turbo Volvo's and Celica's in the past, but this will be my first venture into the KA world. all responses will be greatly appreciated.
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
7psi from a T3 will be in the ~220-225rwhp range I'd guess.
Your cams won't really be beneficial with that smallish compressor, and if it's a straight T3 (Stage I wheel and .63 A/R...?) will not let it flow very well up top, where those cams excel.
If you haven't bought a turbo yet, look into something a little bigger IMO. (Hint: T3/T04E 50-trim)
- Brian
USDM240
i havent gotten the turbo yet, so i could switch.
i could also sell the cams and get a set of stock ones, as the ones i have came in the DE when i bought it. im just trying to keep this project as cheap as possible.
:: orion ::
Keep the cams...they are good.
Just up the turbo size...
I made 224rwhp @ 6psi from my T3/T4 57-trim. Spools to low boost by ~3200, but is making boost anywhere above ~2700-2800 or so...
And with that, you can run a decent sized turbine (.63 A/R, Stage III), not choke off your top end, and have room to grow. All good things...
- Brian
supra brit
Car: '93 Supra, '94 240sx 'vert
Well, if you decide to ditch your cams, I have a 240 you can put them in... :p j/k, don't ditch the cams...
USDM240
thanks for the reply Brian. it makes me feel better to keep the $560 cams, instead of selling them.
i may shoot for a bigger turbo, but i still dont know. its all a matter of money.
